1964 Chevy c10 Truck Fire Pit Build
I wanted to build a fire pit that looked like a slammed 1964 Chevy c10. I started off by designing all the sides on the plasma table. I had to make a few changes to the scale in some areas to get these two dimensional panels to go together.
Once everything was cut it was time to assemble. The finished product uses the hood and roof as gridles for heating or cooking.
Nice build. What thickness steel did you use for the side panels, and did you add any drain or air holes near the base? I’d be curious how it holds up to warping and ash cleanout after a few hot burns.
